vegastrucker702
Aug 15, 2021Guide
XR1000 slow ethernet speed
I recently “donated” my XR500 to my son (different household) and bought myself the XR1000. I have tried everything I have seen mentioned in other threads in here- even the Netgear speed guide, and ev...
- Aug 21, 2021So you should be able to turn this off using the Nighthawk App on your phone in the settings, then reboot from the app, wait 2 minutes before accessing and see if the speeds are improved
Netduma-Fraser
Aug 21, 2021NetDuma Partner
Thanks for the information, are you using Armor by any chance?
vegastrucker702
Aug 21, 2021Guide
Yes, I am using Armor. I didn't know if that could be turned off or not
- Netduma-FraserAug 21, 2021NetDuma PartnerSo you should be able to turn this off using the Nighthawk App on your phone in the settings, then reboot from the app, wait 2 minutes before accessing and see if the speeds are improved
- vegastrucker702Aug 21, 2021GuideOk, thanks, I’ll give that a try
- vegastrucker702Aug 21, 2021GuideThank you so, so much! That seems to have done the trick! After turning off Armor and rebooting, my first test was 901 down, and then 3 consecutive in the mid 800’s. My wifi is still in the 500’s as well. I really appreciate the help!
- Netduma-FraserAug 22, 2021NetDuma PartnerAhh that's fantastic to hear! You're very welcome, glad its all sorted!
