J0nd0e
Jan 27, 2023Follower
Xr1000 slow speeds
I recently bought an XR1000 to improve my internet. I receive these speeds while testing my router on the nighthawk app however, when I test on other devices my speeds can’t get past 200 down. If I ...
Jan 28, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
If I use my default isp router I’m getting 300+ down on all devices but I avoid using it as I receive higher ping.
What can I do to fix this ?
