sweeney515
Apr 12, 2021Aspirant
XR1000 Slow WIFI download speed
Hello i have the XR1000 Wifi 6 gaming router and I have 400 mbps spectrum service which i almost get at ethernet cable direct connect speeds but the wifi I'm only getting around 100 mbps. Any ideas ?...
Apr 12, 2021Guru - Experienced User
what device are you testing with?
Are you testing over 2.4ghz?
5ghz?
What app are you using for testing?
- sweeney515Apr 12, 2021AspirantI am using my desktop pc that has an Intel dual band wireless AC adapter. I am on the 5HZ connection, and using the ookla site speedtest.net
- plemansApr 12, 2021Guru - Experienced User
how far from the router are you?
Have you tried other devices?
what actual intel card is it?What firmware is on the wireless card?
My PC is probably about 25-30 feet away. Signal strength in netsh interface shows 85%. It is the AC 8265 card, I looked at the specs and it seems like it can go to 400 mbps or better on wifi on 5Ghz. I don't see firmware but i see driver version 20.70.19.1. My iphone if i go to the speedtest page in safari gets 400 mbps.
