sweeney515
Apr 12, 2021Aspirant
XR1000 Slow WIFI download speed
Hello i have the XR1000 Wifi 6 gaming router and I have 400 mbps spectrum service which i almost get at ethernet cable direct connect speeds but the wifi I'm only getting around 100 mbps. Any ideas ?...
Apr 12, 2021Guru - Experienced User
what device are you testing with?
Are you testing over 2.4ghz?
5ghz?
What app are you using for testing?
sweeney515
I am using my desktop pc that has an Intel dual band wireless AC adapter. I am on the 5HZ connection, and using the ookla site speedtest.net
- plemansApr 12, 2021Guru - Experienced User
how far from the router are you?
Have you tried other devices?
what actual intel card is it?What firmware is on the wireless card?
- sweeney515Apr 12, 2021Aspirant
My PC is probably about 25-30 feet away. Signal strength in netsh interface shows 85%. It is the AC 8265 card, I looked at the specs and it seems like it can go to 400 mbps or better on wifi on 5Ghz. I don't see firmware but i see driver version 20.70.19.1. My iphone if i go to the speedtest page in safari gets 400 mbps.
5ghz speeds drop off quickly with distance/obstructions. 5ghz also doesn't penetrate materials as well as 2.4ghz so if there obstructions in the way, it can also slow down speeds.
If your phone is getting full speed, I don't think its an issue of the router. You're also a bit behind on the intel driver.
I'd recommend taking a read through this article on wifi misconceptions
