Tots343
Feb 06, 2022Guide
XR1000 SLOW WIFI SPEEDS
Recently just bought a XR1000 gaming router, after setup ive noticed i was getting 85 download which i am paying for 900 down, but getting full 24 up. Ive just set my computer up and hard wired it to...
Tots343
Feb 07, 2022Guide
I’m using a iPhone XS max, air book pro both on 5ghz and right next to the router.
Netduma-Liam
Feb 07, 2022NetDuma Partner
Could you please go to QoS and under Bandwidth allocation, hit 'Reset Allocation' and make sure that Share Excess is enabled from the three-line menu?
After that, retest your speeds and let me know if you're still having the same issue.
- Tots343Feb 07, 2022Guide
okay i tested this and i was running speeds at 550 but why isnt the 2.4 getting full speeds either?
- Netduma-LiamFeb 08, 2022NetDuma Partner
Was 'Share Excess' previously disabled in Bandwidth Allocation? If so, that's why the speeds were reduced.
What exact speeds are you now getting through 2.4 and 5GHz?
- Tots343Feb 08, 2022GuideNo, share excess was not disable.
5ghz averages 500
2.4ghz averages 90
