Tots343
Feb 06, 2022Guide
XR1000 SLOW WIFI SPEEDS
Recently just bought a XR1000 gaming router, after setup ive noticed i was getting 85 download which i am paying for 900 down, but getting full 24 up. Ive just set my computer up and hard wired it to...
Netduma-Liam
Feb 09, 2022NetDuma Partner
OK thanks for confirming, apologies you needed to reset. If you have a spare router lying around, put it between the XR and the modem and test AP mode, if you don't though don't worry about it.
Out of interest, have your speeds improved at all since the reset? When you setup the router again did you put 900/24 as your bandwidth speeds?
Tots343
Feb 09, 2022Guide
It’s okay understandable but no, speeds did not increase at all really stayed the same as I posted earlier, the bandwidth is set to that speed as you posted, I’m just baffled on what could be choking the speeds…
- Netduma-FraserFeb 09, 2022NetDuma PartnerCouple of things to try/double check:
Make sure the router isn't on the floor so it's elevated instead.
It's not on a metal surface as this can interfere with the signal.
Electrical/wireless devices e.g. headphones, remotes etc are not within close proximity >~3 feet if possible
Make the antennae look like this _ | | _ - Tots343Feb 09, 2022Guide
The router has been elevated and away from electroics since we started this process and also the antennas have been in _l l _ the entire time also.
- Netduma-LiamFeb 10, 2022NetDuma Partner
Could you please click the (i) icon next to the Wi-Fi Network on your iPhone then disable Private Address. After this, test your speeds again and see if you're able to get any better speeds.
- Tots343Feb 10, 2022GuideI just ran 4 test and they where all the same
- Netduma-FraserFeb 10, 2022NetDuma PartnerI'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible and retest the speeds: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just did everything as instructed and not any better =/
- Netduma-FraserFeb 11, 2022NetDuma PartnerDo you have a spare router you can put between the modem and XR to see if it gets the speeds then/if it then gets it in AP mode? That would then really give us a good idea of what the idea is and potential next steps.
- Tots343Feb 11, 2022GuideOkay I’ll see what I can do about getting another router. I don’t personally have another one so I’ll have to search around and find one to borrow
