z3thon
Sep 17, 2020Aspirant
XR1000 Spec Sheet?
The XR1000 has a very limited Tech Spec section. I'm looking for information like whether or not it comes with WPA3, what the coverage area is, the different bands it supports 2.4, 5.0, etc. Spee...
- Sep 17, 2020
Netgear has shared details at the level you were inquriing about for the XR1000. Please see here:
https://www.netgear.com/images/datasheet/networking/wifirouter/XR1000.pdf
For additional details you can likely see some hardware teardowns for the RAX50, which has the same hardware :)
In short, no 10Gb ports, Yes 2.4ghz and 5ghz dual-band. And yes, supports WPA3.
Hope this helps.
Is there a more comprehensive tech-spec sheet than what the webpage offers?
Thanks!
Netduma-Fraser
Sep 17, 2020NetDuma Partner
Not as far as I am aware. Reviews should start coming out soon though so you may find more information then.
rinthos
Sep 17, 2020Luminary
Hope this helps.
Thanks!
