jame0174
Apr 27, 2022Tutor
xr1000 speeds cap at 500.But get fool speeds from my modem
For some reason i cant get speeds past 500 on the xr1000.Ihave the cm1200 modem i pay for a gig and i get a gig from modem but not routerI think it has something to do with qos .Any help would be g...
michaelkenward
Apr 28, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
