jame0174
Apr 27, 2022Tutor
xr1000 speeds cap at 500.But get fool speeds from my modem
For some reason i cant get speeds past 500 on the xr1000.Ihave the cm1200 modem i pay for a gig and i get a gig from modem but not routerI think it has something to do with qos .Any help would be g...
Apr 28, 2022Guru - Experienced User
Do you have QoS enabled or disabled?
Are the Sliders configured when QoS is enabled? If so, if you set these for anything less than 99%, you'll see a slower speed test result and thats to be expected when they are being used.
What is the CAT# LAN cable between the modem and router? CAT6 is recommended.
jame0174 wrote:
For some reason i cant get speeds past 500 on the xr1000.Ihave the cm1200 modem i pay for a gig and i get a gig from modem but not routerI think it has something to do with qos .Any help would be great. im going to try the r2 and see how it compares .IFi get max speeds.
