jame0174
Apr 27, 2022Tutor
xr1000 speeds cap at 500.But get fool speeds from my modem
For some reason i cant get speeds past 500 on the xr1000.Ihave the cm1200 modem i pay for a gig and i get a gig from modem but not routerI think it has something to do with qos .Any help would be g...
Netduma-Fraser
Apr 28, 2022NetDuma Partner
As well as the above, where are you testing the speeds, on benchmark or third party speed test? Are you testing via WiFi or ethernet?
