DKE350Z
Jan 26, 2025Tutor
XR1000 Spotify tracks pause before playing next track
I've had a strange problem with my XR1000 router and Spotify. There's a bit involved, so I'll start with the symptoms. When I use Spotify Connect, to stream music to my Anthom MRX1140 receiver, ever...
- Jan 30, 2025That's interesting, well done for determining that, it could be QoS, if you disable this fully from the Congestion Control menu does it still occur?
Netduma-Fraser
Feb 02, 2025NetDuma Partner
Keep QoS enabled but in WAN Settings set NAT to Open and disable the protection options then try again please
DKE350Z
Feb 02, 2025Tutor
I turned QoS back on (traffic prioritisation still on for the Anthem), set NAT filtering to Open, disable SIP ALG, Disable port scan and DoS protection both checked. The pauses came back unfortunately.
- Netduma-FraserFeb 02, 2025NetDuma PartnerOkay thanks for trying, I can pass it on to the team to have a look at but as it's a specific device and updates for the router are new few & far between I couldn't say when/if we may be able to get it sorted
- DKE350ZFeb 02, 2025Tutor
Not a problem, Thank you for persisting, and all your help! At least I can manage for now by turning off QoS when I want to play some tunes.
