NA-cookie
Oct 22, 2023Aspirant
XR1000, Super slow, delayed, laggy, sluggish, un-responsive, missing features, " USER INTERFACE "
why is the UI soooooooooooooooo bad with dumaOS 3.0, 3.1 build .64
Netduma-Fraser
Oct 23, 2023NetDuma Partner
Make sure you're not accessing the interface via HTTPS/that your browser isn't forcing it. Clear your browser cache/cookies then refresh each page on the interface and it will be faster after that. Also if you're using Armor it will slow down the interface.
NA-cookie
Oct 23, 2023Aspirant
that for sure helped a little bit, but its still slow, but its much better thank you.
Also, ( Geo-Filter & Ping heatmap ) tabs will not populate anything, just loading circles, then this message,
" This Rapp is not loaded yet, please try again in a minute "
- Netduma-FraserOct 23, 2023NetDuma PartnerGo to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 4 minutes before accessing and see if it works then please.
- NA-cookieOct 24, 2023Aspirant
did not fix the rapp not loading thing, still nothing.
- Netduma-FraserOct 24, 2023NetDuma PartnerOn the Device Manager, open the menu then resync the cloud, reboot from the interface, wait 4 minutes then check again please.
Make sure you're closing the interface tab when you've started the reboot.
