PapaLung
Sep 10, 2022Apprentice
XR1000 syntaxerror+logs+saved settings
Ok guys, I'm honestly tired of this game I've been playing for months now. Received new xr1000 replacement router from factory. Has been in use less than 3 weeks, still getting these January 24th date...
Sep 10, 2022Guru - Experienced User
Are these log entries causing problems?
Not much can be done with FW changes here in the forums. This would be beyond forum help.
- PapaLungSep 10, 2022ApprenticeLogs are for (in my experience) showing data and failed/completed processes by the network or router. If I knew what the logs meant, I could probably figure out the issue, but, that information far as I can tell, is non existent , hence my question. I'm not asking for new FW either, I'm asking if it's the XR1000 that's the issue and is there another more reliable option I should go to.
- FURRYe38Sep 11, 2022Guru - Experienced User
Please post a snippet capture of what the logs are showing. Please remove any MAC addresses before posting.
