PapaLung
Sep 10, 2022Apprentice
XR1000 syntaxerror+logs+saved settings
Ok guys, I'm honestly tired of this game I've been playing for months now. Received new xr1000 replacement router from factory. Has been in use less than 3 weeks, still getting these January 24th date...
Sep 10, 2022Guru - Experienced User
Are these log entries causing problems?
Not much can be done with FW changes here in the forums. This would be beyond forum help.
PapaLung
Logs are for (in my experience) showing data and failed/completed processes by the network or router. If I knew what the logs meant, I could probably figure out the issue, but, that information far as I can tell, is non existent , hence my question. I'm not asking for new FW either, I'm asking if it's the XR1000 that's the issue and is there another more reliable option I should go to.
- FURRYe38Sep 11, 2022Guru - Experienced User
Please post a snippet capture of what the logs are showing. Please remove any MAC addresses before posting.
