PapaLung
Sep 10, 2022Apprentice
XR1000 syntaxerror+logs+saved settings
Ok guys, I'm honestly tired of this game I've been playing for months now. Received new xr1000 replacement router from factory. Has been in use less than 3 weeks, still getting these January 24th date...
Netduma-Fraser
Sep 11, 2022NetDuma Partner
Looking back at your posts you mentioned the Jan 24th logs before and I said to change the timezone to get that appearing correctly, does that work? I can't see any previous reference to a syntax error, could you provide a screenshot of what you're seeing exactly please?
- PapaLungSep 12, 2022ApprenticeYes, I have changed the timezone. Picture is attached.
- Netduma-FraserSep 12, 2022NetDuma PartnerDid that resolve the date issue then?
For the error, are you forcing a connect to the interface using HTTPS? Even if you're not specifically your browser might be, e.g. Safari does this, could you force HTTP just in case and see if the error goes?- PapaLungSep 12, 2022ApprenticeIt did not resolve the date issue, what's even weirder is that this is not even the same router I began having the date issues with, netgear sent me a replacement and the information is the same, as well as some other settings like the "dont show this again " for the tour, it use to try and take me through it every time id factory reset but not anymore. That's why I'm wondering if there's a copy of that information being stored somewhere else and it's being applied after I factory reset and set up the router. I also just logged in using Microsoft edge, syntac error gone!!! Jan logs still there after reboot.
