PapaLung
Sep 10, 2022Apprentice
XR1000 syntaxerror+logs+saved settings
Ok guys, I'm honestly tired of this game I've been playing for months now. Received new xr1000 replacement router from factory. Has been in use less than 3 weeks, still getting these January 24th date...
PapaLung
Sep 12, 2022Apprentice
Yes, I have changed the timezone. Picture is attached.
Netduma-Fraser
Sep 12, 2022NetDuma Partner
Did that resolve the date issue then?
For the error, are you forcing a connect to the interface using HTTPS? Even if you're not specifically your browser might be, e.g. Safari does this, could you force HTTP just in case and see if the error goes?
