jeremyg237
Dec 11, 2022Luminary
XR1000 the cable modem is scanning for a downstream channel.
All, A new issue has come up. I noticed last night that the internet was getting bogged down. Went and looked at the Netgear cable modem and the downstream light was blinking. I tried to reboot...
Dec 11, 2022Guru - Experienced User
Please post a copy and paste of the CM200 modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
jeremyg237
I keep putting in password for modem and nothing happens.
- jeremyg237Dec 11, 2022Luminary
I tries edge, chrome and firefox. All say not secure. I even allowed and once i put in password nothing happens. The cable between modem and router is a cat6. The ethernet cable that comes with the XR1000 is a cat5e.
- Netduma-FraserDec 11, 2022NetDuma PartnerOne of the ports there is reading as only allowing 100Mbps, switch out the cable for the device that is having the issue and switch it with another, do the speeds improve?
I tried switching different cables. The only thing that works is rebooting both router and modem, butr it only works for a few minutes.
- FURRYe38Dec 11, 2022Guru - Experienced User
I recommend that you change the cable between the XR and CM modem to CAT6A STP.
Factory reset the CM modem and setup from scratch and input a new PW for the modems web page.
