jeremyg237
Dec 11, 2022Luminary
XR1000 the cable modem is scanning for a downstream channel.
All, A new issue has come up. I noticed last night that the internet was getting bogged down. Went and looked at the Netgear cable modem and the downstream light was blinking. I tried to reboot...
Netduma-Fraser
Dec 12, 2022NetDuma Partner
Try setting the XR1000 to use the same MAC address as the XR500 - some ISPs get weird when introducing a new router, if that is the case then the MAC change can prevent that
TheJam
Feb 22, 2023Aspirant
Noticed there's not been an update in a few months. Did you manage to get your XR1000 issue sorted with IPv6?
