Birdizdaword
Apr 22, 2022Aspirant
XR1000 unresponsive and unable to update firmware
I have an XR1000 router which I attempted to update with the latest firmware. Halfway through the update there was a power outage and it corrupted it. The power light was solid orange with the occasi...
Netduma-Fraser
Apr 22, 2022NetDuma Partner
Great advice above, if that doesn't work then it is likely unrecoverable and would recommend pursuing a replacement if you're still covered by warranty
