Birdizdaword
Apr 22, 2022Aspirant
XR1000 unresponsive and unable to update firmware
I have an XR1000 router which I attempted to update with the latest firmware. Halfway through the update there was a power outage and it corrupted it. The power light was solid orange with the occasi...
Birdizdaword
Thanks for the quick reply. I've now tried both tftp and Nmrpflash without success. Tftp is unsuccessful and Nmrp comes up with "Error: Ethernet cable is unplugged". I've tried multiple cords in multiple ports with no success. There doesn't appear to be any activity on the router other than the power light which is just constant white. Hopefully it's still under warranty as I only got it a month ago.
Netduma-Fraser
Apr 22, 2022NetDuma Partner
You should still be under warranty then, would definitely pursue that avenue, either with Netgear support directly or with the retailer you purchased from
