NairoD
May 14, 2023Aspirant
XR1000 UPDATE HELP
I downloaded the new firmware on the netgear's site, https://www.netgear.it/support/product/xr1000#download but when i try to restore the downloaded file it says the file is .chk when the downloaded...
Netduma-Fraser
May 14, 2023NetDuma Partner
Restoring is re-loading settings from a saved config file, the firmware update is what you want, following the link above will get you sorted
