dpl001
Jul 17, 2024Guide
XR1000 Upload
Hello I'm hoping someone can help/point me in the right direction. For about a month now, I've been receiving high upload ping, whilst underload. My hit registration in-game has been really poor in ...
- Jul 18, 2024In most cases like yours it'll be due to PPPoE, disable bridge mode on your ISP router, have it handle PPPoE instead, put the XR WAN IP in its DMZ instead then see if it works as expected
dpl001
Jul 17, 2024Guide
Thanks for the reply.
Yeah I have replaced all cables and even got a new ISP router supplied.
I have the ISP supplied router in Bridge Mode to avoid double NAT.
Unless anyone else has any suggestions, going to the ISP to run tests is the way forward. Just didn't know if it was a known issue due to weird upload/download test results I showed.
Jul 17, 2024Guru - Experienced User
Show them the results since it's happening with there stuff. Once it's resolved there, then you should be good to go with the XR. Any router connected to a ISP modem depends on good signal at the modem.
