FinnV66
Mar 30, 2023Aspirant
XR1000 Username Change
Every video I've seen that shows how to change the username on this router was using the old Genie system and now it's using this DUMAS OS and I cannot figure out how to change my username, unless th...
Netduma-Fraser
Mar 30, 2023NetDuma Partner
Are you referring to the WiFi name? If so go to Settings on the router and you'll see WiFi Setup there.
FinnV66
No actually the Username to log into the router itself. I used to have one, I don’t own an Orbi, but I heard the username on those was permanently “admin” I still have a copy of the old one. Don’t know how or when it changed.
- FURRYe38Mar 30, 2023Guru - Experienced User
admin is the default name and log in for most NG routers. And is not changable.
- Netduma-FraserMar 30, 2023NetDuma PartnerAs above, it can't be changed
