AbrekUS
Jul 25, 2026Aspirant
XR1000 v1 DNS not working when VPN is enabled
I've XR1000 v1 router with the following settings: firmware: 1.0.2.86_2.1.40 IP address: 192.168.2.1 and DNS stops working as soon as I enable VPN on it (see nslookup output below). Resetting ...
AbrekUS
Jul 26, 2026Aspirant
Right now, I'm using 192.168.2.0/24 network for my setup with 192.168.2.1 assigned to the router and 192.168.2.200-254 range setup for the DHCP clients.
However, I've observed the same issue with default setup where router had 192.168.1.1 IP address.
Not sure how this is relevant because this issue is on the LAN part, but router is connected to the provider vie Ethernet cable.
Yes, I'm talking about VPN server embedded to the router.
I don't follow this question: "What happens if you use ISP detected DNS with VPN disabled and enabled?"
The router receives, "detects", DNS server IP addresses from the ISP on the startup and uses them to resolve domain names and it shouldn't change when VPN enabled/disabled.
Even if router would itself would switch to some other DNS servers when VPN is on, why it would start refusing DNS connections from the LAN clients?
Jul 26, 2026Guru - Experienced User
What is the brand and model# of the ISP modem/ONT?
Just checking to see if same thing happens when using ISP DNS vs using custom which you stated using with VPN enabled.
Has this ever worked on this router or is this new to you?
- AbrekUSJul 26, 2026Aspirant
The ISP DNS is used by the router in all scenarios described above.
I've set DNS server IP addresses on the router to 8.8.8.8/1.1.1.1 temporary to test whether it would help with the issue but it didn't so I've switched back to "Get Dynamically from ISP".
Re "Has this ever worked on this router or is this new to you?": what is "this" here?
Everything works fine until "Enable VPN Service" is checked/applied on the router.
After that, LAN clients are getting "connection refused" from the router when they are trying to resolve domain names.
- FURRYe38Jul 26, 2026Guru - Experienced User
Has this VPN feature ever worked for you at all on this router or is this first time you have setup VPN feature?
Have you installed the OpenVPN on your devices and installed the downloaded Windows.zip package on your Windows PC to check all this?
Seems like this maybe an issue with the FW or how VPN is setup on this router when VPN is enabled.
Yes, I've used VPN embedded to the router before w/o any issues and default VPN setting are used:
- TUN Mode Service Type UDP
- TUN Mode Service Port: 12973
- TAP Mode Service Type UDP
- TAP Mode Service Port: 12974
- Clients will use this VPN connection to access: Auto (have tried other options too)
Again, issue is not on the VPN server or VPN clients side.
Issue is that router is not responding to the DNS requests on the LAN side when VPN is enabled on the router.
