  • The best and most likely solution is to do a factory reset which is generally advised after updating to a new firmware version.
  • Thank you for the prompt suggestion - I'll give that a try and report back!
    • FURRYe38's avatar
      What FW version did you load on your V1 router?
      What browser are you seeing this in?
      Does it happen with other browsers?
