esnetca
Jul 18, 2026Initiate
XR1000 v1 "DumaOS is not running!"
After updating my XR1000 v1 to Version 1.0.2.86, http://192.168.1.1 redirects to
https://192.168.1.1/dumaweb/ which only shows
The router does still provide connection to the internet, and https://192.168.1.1/adv_index.htm is accessible.
How do I get DumaOS back up and running?
- esnetcaInitiate
Thank you for the prompt suggestion - I'll give that a try and report back!
- Netduma-FraserNetDuma Partner
The best and most likely solution is to do a factory reset which is generally advised after updating to a new firmware version.
