FreddieS
Feb 15, 2025Apprentice
Xr1000 V2 having DNS issues and unable to connect to websites
I just bought this router and i am having some series issues. I have updated to the latest firmware and did all the suggested things. Is anyone else having these issues and has anyone fixed it? I ha...
Feb 15, 2025Guru - Experienced User
Try a different DNS Server. Here's a few. Also remember to change the ipv6 dns server if ipv6 is enabled.
CloudFlare
IPv4: 1.1.1.1 and 1.0.0.1
IPv6: 2606:4700:4700:0:0:0:0:1111 and 2606:4700:4700:0:0:0:0:1001
GoogleDNS
IPv4: 8.8.8.8 and 8.8.4.4
IPv6: 2001:4860:4860:0:0:0:0:8888 and 2001:4860:4860:0:0:0:0:8844
FreddieS
I currently have it on Googles DNS. Still same issue. I contacted my ISP and they are sending me out a new modem. I do not have v6 enabled. And i did not change the pool to 100 - 200 this time around. My Firmware is 1.1.0.22_2_1_34 . It does say there is a firmware update on top but i am assuming to ignore that? The update it wants to give me is 1.1.0.16_2.1.25 .
- plemansFeb 15, 2025Guru - Experienced User
what modem do you have?
does it work if a pc/laptop is directly connected to the modem?
It shouldn't be asking you to update if you're actually on the latest. I'm wondering if maybe you have those backwards?
- FreddieSFeb 15, 2025Apprentice
The Modem is one i get from my ISP. Not sure the brand? the firmware i updated to the one i have now because of whats in the forum and said to update to that one. the firmware it is asking me to update. When i updated it when i first got the router it kept asking me to update it everytime i flashed it so it seems like a glitch? Not sure.
You should be able to look at the modem and get a model number off it.
And do devices work connected directly to the modem?
