FreddieS
Feb 15, 2025Apprentice
Xr1000 V2 having DNS issues and unable to connect to websites
I just bought this router and i am having some series issues. I have updated to the latest firmware and did all the suggested things. Is anyone else having these issues and has anyone fixed it? I ha...
Netduma-Fraser
Feb 15, 2025NetDuma Partner
How is it worse exactly if you can't connect to any websites?
FreddieS
it can connect to websites. It can take a long time. And a lot of the time it times out.
- Netduma-FraserFeb 15, 2025NetDuma PartnerIs it this specific PC you're having the issue with or are other devices having the issues as well?
- FreddieSFeb 15, 2025Apprentice
Yes having issue with a Laptop. It is running through wifi, and is running windows 11. My Pc is ethernet cord and is running windows 10.
- Netduma-FraserFeb 16, 2025NetDuma PartnerHave you changed any network settings on the devices themselves or are they using automatic settings?
- FreddieSFeb 16, 2025Apprentice
whatever is default .
- Netduma-FraserFeb 16, 2025NetDuma PartnerCould you disable the Adblocker on the router and see if it works then please?
- FreddieSFeb 16, 2025Apprenticeadblocker is and has been disabled.
- Netduma-FraserFeb 16, 2025NetDuma PartnerI think it may be best to wait for the new modem from your ISP and then test directly to that. I know you don't get the exact same issue on your modem currently but what you are experiencing directly to it isn't normal either so quite possible that modem is faulty. If you don't on the new modem but still do on the XR then it narrows it down a bit.
ok Thanks. should be here in 2 days.
- FreddieSFeb 19, 2025Apprentice
Ok got new Modem today. Still same issue. I ordered a new XR1000 replacement should be here by thursday. If you want to do some testing i am game. i am wondering if its the new firmware update or possible hardware? Thanks.
I intalled the firmware update it keeps asking me to install on the top. So i believe i went backwards in firmware? It seems to be working well now. We will see in a few hours if i have the same issue. Might be the new firmware update. I used 7zip to unzip it.
Ok still having the same issue even going back on firmware. getting new router tomorrow from Amazon.
- MrGrumpyFeb 20, 2025Star
I'm having the same issue. Internet is "lost" for thirty seconds to a minute. Error messages often reference "DNS". It then comes back. Interestingly during one of these outages, I could access my NASs, but not the modem (on its "management when in modem mode" address, 192.168.100.1)
The Nighthawk has been in use since June 2024, but these failures started about 10-15 days ago.
Modem is a Virginmedia HUB4 in "modem" mode. It's about a week old (coincidence?). VM decided I needed a new modem/hub, but the issues started before it was installed - indeed it was while on the VM site looking for answers, that they offered a new hub.
Nighthawk firmware is XR1000v2-V1.1.0.22_2.1.34.
Started out with settings for "Internet IP Address" & "DNS Address" as "Get Dynamically/Automatically from ISP"
Router MAC Address is "Default"
Adblocker is not enabled.
Currently using Static addresses for DNS Servers, namely 8.8.8.8 (Google) and 194.168.4.100 (VM's "primary DNS server")
- Netduma-FraserFeb 20, 2025NetDuma PartnerPut the VM in router mode and just test with that without the XR1000 involved, if you get the same issue then it's not the XR
)Hi,
yes that was my next idea.
The Nighthawk has one Ethernet connection, which is to a Cisco gigaswitch - all the downstream units hang off the Cisco. So as an experiment I moved the Ethernet cables for the two main PCs from the Cisco straight into the Nighthawk.
No change: conclusion is the problem is upstream of the Cisco. Strike one, LOL.so then I work upwards, and the choice is either (a) factory reset of the Nighthawk, or (b) take the Nighthawk out of circuit using the VM Hub as router. So discussing this with “the management” - and to be fair, she used to be the IT Director for her organisation - were going for option (b)!
However as she has pointed out “never start an IT project on a Friday afternoon” (and she has had some experience of this……..)
so it will be a couple of days before I get round to it, and TBF, it works most of the time, but with a few glitches that shouldn’t be there.
And I do find it coincidental that these issues arose, and we “suddenly” needed a new modem!
Hey ho!
Even though my degree is Computer Science, I went into spacecraft electronics engineering……it’s a damn sight easier than IT! 😂
- Netduma-FraserFeb 20, 2025NetDuma PartnerVery sensible, yes the timing is a little odd! I did always find the modem mode to be temperamental personally on the older hubs, so I'd suggest if it is okay when you test it that way to put the XR in its DMZ instead of using the bridge mode and then see if it works better.
- FreddieSFeb 21, 2025ApprenticeOk got the newerish router. Setting up now. Any suggestions?
Man i was hoping this was going to get solved with new Router i was trying to recreate the situation and just a few minutes later it happened. Just for a second but it happen. Keep you updated. Any thoughts or suggestions?
Turning off Adblocker now. See if it happens again.
- Netduma-FraserFeb 21, 2025NetDuma PartnerAs in the issue happens without the XR and just with the new VM hub? You'll have to contact them
ok sounds good. I am going to wait a week or so. So far it has only happend a couple of times. i am getting some DoS stuff on the router., Not sure if that should be of concern. Thanks.
ok so far no issue with the New Modem directly plugged in. I do notice a little lag. But does not time out.
- Netduma-FraserFeb 21, 2025NetDuma PartnerAppreciate the update, fingers crossed it continues that way!
- robturpinFeb 23, 2025Apprentice
Hi folks. I'm glad that I'm not the only one experiencing this frustrating issue.
So I first noticed it about a month ago as well, and that's about when I switched from using my Arris Surfboard cable modem to Xfinity's XB8. SO, naturally I assumed (incorrectly it turns out) that their XB8 had introduced and was the root cause. After much troubleshooting however, that doesn't seem likely. I worked with Xfinity tier 2 internet support and we eliminated my router, switch, etc. and just went coax > modem > ethernet > single computer and poof - the issue was gone and unreproducible.
Then, I began reintroducing the rest of my components into the network one at a time, and as soon as I reconnected my XR1000v2 router - BAM - issue's back! This happens on all pc's and laptops, in all of the major browsers (Chrome, Edge, Firefox, Opera), and with almost any website (when it actually happens, which is very random). As the OP stated, I'll open up and/or browse to a website and it instantly starts spinning and ends in a few dns errors, but within 1-2 minutes the website(s) all pop up and everything works fine again.
Next I completely factory reset it and set it up as basic as possible, and it seemed ok for about a day, but sadly the issue popped right back up within 24 hours.
I'm literally at my wit's end trying to figure this thing out. Is there any network troubleshooting software or something that can help up 1) determine exactly what is happening, and 2) which piece of hardware is causing this?
I guess our common devices is our first clue to determining if it actually is an issue with the XR1000v2.
By the way, I'm using a Xfinity XB8 modem/gateway (in bridged mode with custom security settings opened up as wide as possible - every security feature disabled), a NetGear XR1000v2 router, a NetGear GS108 8-port unmanaged gigabit switch, everything including all pc's and laptops connected using CAT6 550MHz cables.
- MrGrumpyFeb 23, 2025Star
OK so today is the big testing day. I've removed the Nighthawk and rebooted the VM Hub 4 into "modem + router" mode. LAN is back up and running (both wired and wireless segments).
So we will see what happens! Wish me luck!
