zeth07
Apr 11, 2025Aspirant
XR1000 v2 Low Speeds all of a sudden
For some reason I am getting low speeds now, we pay for 500/20 and when the router isn't hooked up it works fine since I just tested it separately before and after. I haven't changed any hardware bet...
Apr 11, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Same speeds seen with Ooklas installable speed test app on a wired PC or laptop?
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
- zeth07Apr 11, 2025Aspirant
Firmware: xr1000v2 1.1.0.22_2.1.34
Modem: Netgear Nighthawk CM2000
Yes the app speedtest is showing the same speeds as Fast, but as shown the router itself is saying otherwise.
I've done a power cycle last night and today just trying to test it again and it didn't matter. Besides the fact that it worked fine when it was just the modem anyway when I tested it.
The ethernet cables I'm using are the ones that came with the product/s. I'm using the black one going from the modem to the router, and the yellow one is going from my router to the PC. The yellow one worked fine when it was just the modem to my pc. I guess I could test the black one again on its own but it doesn't really make sense for that to be a problem when the ROUTER SPEED TEST is showing the correct speeds.
I feel like I have done a factory reset after the firmware update because I was already having different problems before.- FURRYe38Apr 11, 2025Guru - Experienced User
I would presume that the speed test point that the router uses may differ from what Fast.com or Ookla uses and maybe under some sort of busy status thus maybe giving some slower result. I would not put too much concern over this. If your getting to speed speeds with Fast and Ooklas then you should be good all around and be fine. I tend to pick results from speed test apps over onboard speed tests and these can differ over time. External test apps tend to be more accurate.
Maybe you misunderstood but the speeds on Fast and the app are completely wrong and way off from what I'm paying for which is the problem. The point being the speeds show up fine when it's just the modem connected but wrong when the router is connected when I haven't changed anything otherwise within any kind of expected time period for this to start happening.
- Netduma-FraserApr 11, 2025NetDuma PartnerYou've set the download to 400 on the router so set that to 500. Then also provide a screenshot of the QoS page please - have you made any settings changes recently?
It was set to 400 since that was what we had previously and only recently did my ISP upgrade it to 500 but I didn't think that was really relevant anyway.
I don't use the QoS because whenever I tried to actually use it nothing seemed to change to make it be any kind of benefit. We hardly use any of the bandwidth given in the house at a given time so I seriously doubt the QoS would ever actually come into play which is why I've had it disabled.
The speed tests are basically showing 10 times less than the speeds we should be getting.
