Rowns
Nov 25, 2023Tutor
XR1000 V2 NetDuma Firmware Not Updating/Showing Correctly
I recieved this router yesterday and I have already had to hard reset it to get my wired devices to appear under device manager. Now when I'm logged into the router via web browser on my PC, it c...
Rowns
Nov 25, 2023Tutor
Also no matter how I tweak the QOS settings, I keep getting massive underload ping spikes for downloads. Any suggestions on how to fix this?
Netduma-Fraser
Nov 26, 2023NetDuma Partner
You're on the latest firmware so you can ignore that. Are you using Armor or connecting to the interface using HTTPS?
Have you got Congestion Control set to Always?
- RownsNov 27, 2023TutorThanks for the response.
Armour is disabled as I have no intention of paying for it after the trial. And yes CC is set to always on.
How do I check the http/https
It just shows the ip/desktop, etc in the browser.- Netduma-FraserNov 28, 2023NetDuma PartnerWe're still improving the Connection Benchmark results so it's probable it's not as bad as it looks. Also if you have Congestion Control active at all that will eliminate bufferbloat so wouldn't be as bad as shown.
Use http://192.168.1.1 or http://routerlogin.net specifically to access- RownsNov 29, 2023TutorOk then. When is it likely to be fit for purpose? As I’ve seen over comments dating back some time stating it’s being worked on.
With respect to the QOS I’ve left them at 70% for each, but is there a limit to what I should set the application percentage to? So for example gaming is 40%, is that too high? Could that be impacting other areas as performance on my phone for example is terrible at times with pages refusing to load. If I enable airplane and drop to 5g it loads fine so it’s definitely the WiFi signal.
