Rowns
Nov 25, 2023Tutor
XR1000 V2 NetDuma Firmware Not Updating/Showing Correctly
I recieved this router yesterday and I have already had to hard reset it to get my wired devices to appear under device manager. Now when I'm logged into the router via web browser on my PC, it c...
Rowns
Nov 29, 2023Tutor
Ok then. When is it likely to be fit for purpose? As I’ve seen over comments dating back some time stating it’s being worked on.
With respect to the QOS I’ve left them at 70% for each, but is there a limit to what I should set the application percentage to? So for example gaming is 40%, is that too high? Could that be impacting other areas as performance on my phone for example is terrible at times with pages refusing to load. If I enable airplane and drop to 5g it loads fine so it’s definitely the WiFi signal.
Netduma-Fraser
Nov 29, 2023NetDuma Partner
We have a new beta update coming out soon which should be better. I would suggest resetting Bandwidth Allocation to default and experimenting with Congestion Control and Traffic Prio. 70% is a recommended starting point but may not be the best for everyone
