mtabikha
Apr 05, 2022Aspirant
XR1000 VPN
I was wondering if it is possible to set up Open VPN (OctoVPN provider) on my router. i want to provide a VPN IP address to my gaming console instead of using my mac/windows to host Open VPN.
michaelkenward
Apr 06, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your XR1000 device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will move your message to the appropriate section.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
