ssssss
Jan 24, 2023Tutor
XR1000 vs XR1000v2: the difference?
Anyone know the difference between these two hardware versions? Thanks,
ssssss
Jan 24, 2023Tutor
- Netduma-LiamJan 24, 2023NetDuma Partner
There was an issue with supplying some hardware for the XR1000, so they had to use different but comparable hardware instead. The performance will be the same between the two, it's just a case of any new XR1000s purchased will now be 'XR1000v2'.
- FURRYe38Jan 24, 2023Guru - Experienced User
Does this still use same FW code base and I presume same release FW between the v1 and v2?
- Netduma-FraserJan 24, 2023NetDuma PartnerFirmware is not compatible with both, there will be separate firmware versions for each
