ssssss
Jan 24, 2023Tutor
XR1000 vs XR1000v2: the difference?
Anyone know the difference between these two hardware versions? Thanks,
Netduma-Fraser
Jan 24, 2023NetDuma Partner
Firmware is not compatible with both, there will be separate firmware versions for each
Jan 24, 2023Guru - Experienced User
Good to know. Thank you Sir.
