PapaLung
Jun 02, 2022Apprentice
XR1000 Warzone Xbox servers
Hello, I'm new here so please forgive me if I don't explain this clearly enough, but, here goes. I have an Xbox series X that I'm trying to use in conjunction with this router. The geofilter shows a w...
- Jun 03, 2022The Geo-Filter doesn't show your location, that will be a server or a server that is misclassified as a peer that you are connected to
Jun 03, 2022Guru - Experienced User
Can you get into a game if you don't configure GeoFilter at all?
- PapaLungJun 03, 2022ApprenticeFirmware is the current version, Modem is a CM2050V Nighthawk. I can get into games with or without the geofilter activated, my issue is being able to access the server closest to me. Thank you for your response!!!
- Netduma-FraserJun 03, 2022NetDuma PartnerUnderstood, as Utah is on the West Coast and they seem to have stopped using West Coast servers you will be getting East Coast every time and that isn't something we can specifically help with. If/when they bring those servers back then we can help you force them. I'd suggest trying to force once a day, then if it doesn't work force the lowest ping server to you on the East Coast.
- PapaLungJun 03, 2022ApprenticeI can get west coast servers no problem, it's being able to connect to the server closest to me that is my issue as well as the location the geofilter shows me being.
