PapaLung
Jun 02, 2022Apprentice
XR1000 Warzone Xbox servers
Hello, I'm new here so please forgive me if I don't explain this clearly enough, but, here goes. I have an Xbox series X that I'm trying to use in conjunction with this router. The geofilter shows a w...
- Jun 03, 2022The Geo-Filter doesn't show your location, that will be a server or a server that is misclassified as a peer that you are connected to
Netduma-Fraser
Jun 03, 2022NetDuma Partner
Could you provide a screenshot of your Geo-Filter page please? Are you referring to the in game region showing you in CA? If so that's nothing to do with the router, it's where your IP is indicating you are - likely it used to be an IP for that location. Also I've seen a lot of evidence to suggest that for some reason they are not currently using West Coast servers for some reason - you could confirm this by disabling the Geo-Filter and play 10 games for example, they'll all be East Coast.
- PapaLungJun 03, 2022ApprenticeI've attached a photo (don't mind the dusty screen đŹ) and thank you for your help!!!
