PapaLung
Jun 02, 2022Apprentice
XR1000 Warzone Xbox servers
Hello, I'm new here so please forgive me if I don't explain this clearly enough, but, here goes. I have an Xbox series X that I'm trying to use in conjunction with this router. The geofilter shows a w...
- Jun 03, 2022The Geo-Filter doesn't show your location, that will be a server or a server that is misclassified as a peer that you are connected to
Netduma-Fraser
Jun 03, 2022NetDuma Partner
Understood, as Utah is on the West Coast and they seem to have stopped using West Coast servers you will be getting East Coast every time and that isn't something we can specifically help with. If/when they bring those servers back then we can help you force them. I'd suggest trying to force once a day, then if it doesn't work force the lowest ping server to you on the East Coast.
PapaLung
Jun 03, 2022Apprentice
I can get west coast servers no problem, it's being able to connect to the server closest to me that is my issue as well as the location the geofilter shows me being.
- Netduma-FraserJun 03, 2022NetDuma PartnerIf you want to try that specific location then you'll need to remove the other polygons you have setup as you could get any servers within those areas at any time
- PapaLungJun 03, 2022ApprenticeI've done that as I explained in my initial post, the picture I uploaded was in reference to my actual location and where the geofilter shows I am.
- Netduma-FraserJun 03, 2022NetDuma PartnerThe Geo-Filter doesn't show your location, that will be a server or a server that is misclassified as a peer that you are connected to
