PapaLung
Jun 02, 2022Apprentice
XR1000 Warzone Xbox servers
Hello, I'm new here so please forgive me if I don't explain this clearly enough, but, here goes. I have an Xbox series X that I'm trying to use in conjunction with this router. The geofilter shows a w...
- Jun 03, 2022The Geo-Filter doesn't show your location, that will be a server or a server that is misclassified as a peer that you are connected to
PapaLung
Jun 03, 2022Apprentice
I can get west coast servers no problem, it's being able to connect to the server closest to me that is my issue as well as the location the geofilter shows me being.
Netduma-Fraser
Jun 03, 2022NetDuma Partner
If you want to try that specific location then you'll need to remove the other polygons you have setup as you could get any servers within those areas at any time
