ATN90
Dec 11, 2025Aspirant
XR1000 What/Where is the Latest Firmware?
I have a XR1000 and my current firmware seems to be 1.0.64.18_5.0.19. On the support page for the XR1000 under 'Firmware and Software Downloads' it says "Firmware Version 1.0.2.86" with "Latest...
- Dec 12, 2025
The latest is the one you downloaded and you upload the .chk file to the router on the firmware update page
Dec 12, 2025Guru - Experienced User
Is this an ISP supplied device? Or did you pick it up used?
Because that firmware matches the RCN version of the XR1000.
https://www.netgear.com/support/product/xr1000-1rnnas-rcn
