SmokeyOdin
Jun 25, 2022Tutor
XR1000 WiFi Problems
Hi All I've been getting this problem when making any changes in the GUI (ie: static ips for computers etc, port forwarding, changing wifi name etc etc) the WiFi speed drops to about ~5% of my wi...
- Jun 26, 2022
ok so quick update this morning, I fixed it last night by changing the 5Ghz channel band from 44 to another one and its working perfectly now!!
SmokeyOdin
Jun 25, 2022Tutor
Hi,
Yeah the VHub is in modem mode and using the SpeedTest app to test speeds, this has only just started happening over the last week or so and I'm just coming up to having the router for 3 months now
Netduma-Fraser
Jun 25, 2022NetDuma Partner
I have VM as well and find the modem mode to be a little finicky, could you use the DMZ instead and see if that helps at all with the WiFi speeds?
- SmokeyOdinJun 26, 2022Tutor
