Bellum
Oct 27, 2021Aspirant
XR1000 will not retain settings - resets to factory settings -
My Nightawk Gaming Pro router XR1000 will not keep settings and now will not allow the password to change from the default password. Netgear support has not been helpful. The hardware warranty is...
Netduma-Fraser
Nov 02, 2021NetDuma Partner
Sorry to hear you're having issues, we'll do our best to help you here. What web browser/device are you using to access the interface/change settings? Is it all settings changed that don't save or specific ones?
Bellum
Nov 02, 2021Aspirant
Hello and thank-you for the help,
The browser is Microsoft Edge.
Currently the I cannot change the password from the default and I used to be able too.
The router seems to reset itself back to the factory settings every couple weeks.
After the last rest, the ability to change the password seems to be lost.
Other settings are maintained until the reset happens. Really the only settings I change are the dynamic wifi, forwarded ports, router name, and passwords.
The phone app takes way too long to access the settings and It also does take seconds when I use Edge.
- plemansNov 02, 2021Guru - Experienced User
Have you tried a different web browser? Like firefox?
What firmware version are you on?
- Netduma-FraserNov 02, 2021NetDuma PartnerWhat happens exactly when you try to change the password or is the password not there? Are you unplugging the router every few weeks by any chance?
- BellumNov 02, 2021Aspirant
I am running :
XR1000 1.0.0.58_1.0.44
which seems to be the latest firmware.
I am not unplugging the router every few weeks.
I did make a back up settings file, but the old one did not work when I tried to restore from it.
The password was able to be changed this time when I enabled the password reset feature ( for when you forget your password ).
Does the router reset to default (factory) if power is lost?
- Netduma-FraserNov 02, 2021NetDuma PartnerIf you haven't rebooted the router from the interface which acts as a hard save then it is possible settings can become lost if there is a power outage/the router is unplugged. Set everything up, then reboot from the interface and see if it lasts longer than previously.
