TurnupDig75
Nov 11, 2022Aspirant
Xr1000 Xbox nat type unavailable
My Xbox series X nat type is always unavailable I have turned on open nat type in DUMA OS
TurnupDig75
Nov 15, 2022Aspirant
yes but I have changed it back to secure
I don't have geo-filtering on
Netduma-Liam
Nov 16, 2022NetDuma Partner
OK, could you leave that set to open, as that will help.
Do you know if you're using IPv6? If so could you test disabling it temporarily from the XR1000 interface advanced settings. Then check if you're having the same issue on the Xbox.
