testrada1542's avatar
testrada1542
XR1000
My nighthawk XR1000 keeps getting disconnected from my modem i’m running an arris surfboard along with 800mbps speed it does this frequently when i log into the app or go online it says “connection: offline” does anyone know why
  • plemans's avatar
    what arris surfboard is it?
    How frequently is it happening?
    Does it happen to all devices or only 1?
    Happen to just wireless devices? or both wired and wireless?
    • testrada1542's avatar
      testrada1542
      it’s an arris surfboard sb8200 and the devices don’t disconnect. the actual router displays that the connection is offline it usually happens towards the end/beginning of months and it’s both hardwire and wifi
      • plemans's avatar
        are you using port aggregation on the sb8200?
        i've got one I've tested on xfinity with a couple routers and it wasn't stable using its port aggregation
