Retired_Member's avatar
Retired_Member
Dec 08, 2022
XR1000
I'm Having an issue with the connection of my new XR1000 for some reason whenever I format my router it defaults  to static  and my internet is dynamic. Also. When I go in my Duma OS manually without having to put my stuff in and switch it to dynamic, I still don't have it When I hook up my XR 450 that works. No issue except connection problems with the speed And this is a new XR1000 I don't know why this is happening I called my ISP to make this my main Router
  • What problem is this causing exactly?
    What's the make and model of the modem the XR1000 is connected to? Is it a pure modem or does it also have Wi-Fi functionality?
    • Retired_Member's avatar
      Retired_Member
      Never mind I fixed it. You can close the portal
      • FURRYe38's avatar
        Would you please give details on how you fixed it?
  • FURRYe38's avatar
    What browser are you using?
    Try MS Edge or FireFox
