Vinstrong's avatar
Dec 08, 2022
XR1000
HI all.
Purchased and installed the above router, however i can't seem to get the geofencing to work. I keep getting errors, like this:
Error: RPC error 'ERROR_CMDFAIL': Exec '//usr/bin/geoip -m 1719 -f /tmp/geoip_ipc2' failed with 1
 Can anyone please steer mer in the right direction?
TIA.
  • Could you please try removing all profiles you've added to Geo-filter, then re-add the one you need. I believe this issue can occur if you've got overlapping filters, so make sure your profiles aren't filtering the same thing.
  • FURRYe38's avatar
    What FW version is currently loaded?
    What Browser are you using?
    Vinstrong wrote:
    HI all.
    TIA.
    • Vinstrong's avatar
      Vinstrong
      Tutor
      Version XR1000 1.0.0.64_1.0.49
      Using chrome, have cleared cache and history.
      So i am now seeing data on the geo filter page (similar to what ive seen on you tube) ,however after loading up PS5 with call of duty MW2, latency still shows 200ms ,even though i have only Australia within my fencing. Am i missing something?
      TIA
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Can you provide a screenshot of what you're seeing on the map when you're in a game?
