jamieskon
Mar 29, 2025Aspirant
XR10000 - Schedule not working
Scheduling does not go off at designated time and the tick box after apply does not stay ticked. Timezone set correctly and GMT is calculated correctly
Netduma-Fraser
Mar 29, 2025NetDuma Partner
Can you provide a screenshot of the scheduling page please?
- jamieskonMar 29, 2025AspirantScreenshot attached thanks
- plemansMar 29, 2025Guru - Experienced User
don't you have to check the box above the device that enables turning it off by schedule? I attached your photos and circled it.
- jamieskonMar 29, 2025AspirantCorrect - I do tick that box circled. Once I click apply the tick incorrectly automatically is non ticked and removed. Therefore the tick does not stick
- Netduma-FraserMar 29, 2025NetDuma PartnerAs above, if you do that does it work?
