zeth07's avatar
zeth07
XR1000v2 - 2 Wired devices keep randomly showing offline in Device Manager + Other Issues
I recently got the XR1000v2 and when I was trying to set it up on all my devices and label them correctly so I knew what was what to monitor if random things would take up bandwidth, I was noticing t...
  • Netduma-Fraser's avatar
    Dec 20, 2024
    It switches to offline when there is no active traffic and will switch back on when there is, it has no affect on the functioning of said device.
    What is the model of the modem/router the XR is connected to and how have you set that to ensure all traffic flows to the XR? E.g. XR in its DMZ, modem/bridge mode
    Access via the IP instead 192.168.1.1 or 10.0.0.1 and see if it happens less.
