zeth07
Jul 05, 2026Aspirant
xr1000v2 - network spikes higher shown than real usage?
xr1000v2 1.1.0.22_2.1.34 While I'm monitoring my network to see what is causing lag spikes, I've seen that the "Network Overview" is showing spikes much higher than what ANY DEVICE is showing in ...
- Jul 05, 2026
Not sure how all that maybe calculated. May depend on actual data flow between the device and router and what router is actually seeing.
Your FW is behind, might update it and check to see if anything changes.
Netduma-Fraser
Jul 06, 2026NetDuma Partner
Downloads don't happen at a steady pace, they go up and down all the time hence why even when it is 'steady' you can see it's still fluctuating, spikes can happen but it's not indicative of an issue. Overview shows this more live view of the traffic and snapshot shows you the summary/average like how you would see anywhere showing your download speed.
Jul 06, 2026Guru - Experienced User
FURRYe38 wrote:Not sure how all that maybe calculated.
Could well be part of the puzzle. The top graph might have more smoothing, as it is intended to show total usage, not spikes.
Have you looked for packet loss (which often results in packet retransmission)? That could also cause lag.
