t100
Feb 07, 2025Tutor
xr1000v2 doesn't upgrade in Dumas or app to firmware 1.1.0.22hotfix
the nighthawk app doesn't find the new firmware. The dumas router login also doesn't show new firmware and keeps trying to update to a version of 1.1.0.16 firmware which it already has. When you man...
Feb 07, 2025Guru - Experienced User
Do NOT attempt to open the .chk file after unpacking it. This file is complete and can only be used by the routers web page. You can manually update the router using the routers web page and a web browser:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
