t100
Feb 07, 2025Tutor
xr1000v2 doesn't upgrade in Dumas or app to firmware 1.1.0.22hotfix
the nighthawk app doesn't find the new firmware. The dumas router login also doesn't show new firmware and keeps trying to update to a version of 1.1.0.16 firmware which it already has. When you man...
Netduma-Fraser
Feb 07, 2025NetDuma Partner
Exactly as above, let us know how you get on
t100
Feb 08, 2025Tutor
It did not work. Tried to use the .chk file but it didn't upgrade. Still says version 1.1.0.16_2.1.25. This is file name after unzipping
Doesn't the .chk in file name and description recovered file fragments mean there is a problem with the file? I tried to use it because you guys said so, but it didn't work. Thanks for any other suggestions. Again the dumas software and nighthawk app don't find the newest hotfix firmware.
- Netduma-FraserFeb 08, 2025NetDuma PartnerThe router won't find the hotfix because Netgear haven't pushed it to the router, so you have to upgrade manually. I can't see the image so can't comment on that but it's a router file, not a file you open on your PC so you can ignore whatever the PC says. You uploaded the file to the router and what happened exactly, did it appear to upgrade but after it completed the number was the same or did you get an error trying to upgrade?
- t100Feb 08, 2025Tutor
It finally updated after hardware reset and redownloading and unzipping a 3rd time. ty.
